1 - 2 of 2 Posts
Hi everyone does anyone know if the wiring looms in the drivers side door and the pasenger side front door are iiidentical.The reason i ask is i have damaged my door and i,m looking for a replacement door in the same coulour.Now i have sourced a good door to replace mine but the problem is the door is off a LHD evoque and all the window switches and mirror switches are on that side so i need to know if i fit the door and put my loom in and my door card will everything work as it does now.TIA
I would swap everything from your old door, e.g. the door card, loom, switches, Mirror etc. Then it should work fine, i'm sure the metalwork shoudl be identical, but the looms wont be, so use yours and if it all fits it'll work.
Reactions: threelander
1 - 2 of 2 Posts
