1 - 5 of 5 Posts
Hi everyone,
Got my car back from Pentland Land Rover on Wednesday, it was the steering rack problem that's been discussed recently, anyway since I have had it back the fron wipers have started to squeak, today I replaced the wipers with new Bosch ones, but the squeaks still there, I have since lifted the drivers one away from the window and turned the wipers on, and the squeaks coming from the assembly, has anyone had this kind of issue and is it an easy repair?. I've only had the car 5,5 months and I'm starting to regret buying it, as its been in the garage twice already since I bought it. (2014 Pure 33k)
As painful as it may be, you should probably ask Pentland as they may have not put something back properly if it started after they did the work, as never heard anyone mention this before.
Have you tried with both wipers off of the screen????? If it still squeaks then it must be the assembly.
Careful if you pull the wipers up to test this as they can touch the Evoque bonnet/paint!
Good shout, it pays to check this sort of thing. (y)
1 - 5 of 5 Posts
