1 - 17 of 17 Posts
Can you help me please Techno people.......
I have an Evoque SE on my works car park having an issue with the passenger window raising and closing in 3 or 4 inch increments.
So basically it takes about 5 presses of the button to open and close.
I have tried the usual trick of holding the switch up for 6 seconds to re-calibrate but then when i press it down it just drops an inch or so and at one stage i thought it had packed up.
Surely there isnt a fault and it just needs calibrated - but my calibration methods arent working.
What am i doing wrong ?
Have you tried puting it right down and holding it there for a few seconds then right up and holding it for a few seconds or only done one way ?
As window is up......i press for 6 seconds.....release.....then press down.
No matter whether I hold down or not it stops after about 2 or 3 inches.
Done the opposite. Window down....hold for 6 seconds,,,,then up and it rises about 2/3 inches.
It takes 6 switches of the button to either open or close.
It's definately a re calibration, but not having it?
Sounds to me like it's broke?
If it was your car Id believe that......
My windows work
Perhaps if you wore your Spiderman outfit it might have made a diference
Its a new work colleague so dont want to frighten her wearing tights.....
Claybuster.......I expected it off Yoda......but you have dissapointed me....
Given that the auto window function needs to be reset after the battery has been disconnected, try disconnecting the battery for a few minutes and see if that fixes it.
If not, then it looks like a dealer visit is required.
Air con, who uses windows these days lol
The worry with the battery disconnect is when connecting again, apart from windows having to be re set.....what other issues will it bring.
Im sure others who have disconnected battery or had new battery have had to take to dealer for other issues ????
No Spidey, not in my case. I had a new battery fitted a couple of months ago and all that was necessary was to reset the window auto close.
Mine is an old log burner (2.2), the electronics might be different on Ingenium models.
Discussion Starter #16
Cheers Recordman.....Its a 2.2 transit as well, 2011 model.....thanks for that,......hopefully she tried it last night as I told her to....and it starts this morning
Sorry if I disappointed you but Yoda's sarcasm is obviously infectious and I must have a low susceptibility threshold!
I must try harder to resist!
1 - 17 of 17 Posts
