Do you have any photos or part numbers please, and where is it located?I’ve just replaced the dab module with a dab+ Module, it only requires a new power connector as it’s different to the original, it’s literally plug and play, retune the new module and you have all the dab & dab+ stations 👌
Thank you, I think I will do the same to mine. Much appreciated 👍🏻👍🏻👍🏻There are loads of modules on eBay as it’s used across the range... but the adaptor you’ll need to get from LR unless your eBay module comes with cut off plugs attached 👌
btw our evoque is a 2013 👍
Ooh, sounds good. Is it difficult, I'm ok ish but not a technophobe, but can find my way around if not too difficult 🤔. Sounds like what I need 👍Thank you, I think I will do the same to mine. Much appreciated 👍🏻👍🏻👍🏻
it’s just a case of 3 plugs and 2 bolts to swap the moduleOoh, sounds good. Is it difficult, I'm ok ish but not a technophobe, but can find my way around if not too difficult 🤔. Sounds like what I need 👍
Thanks, that is great I have now just found this on the Jaguar forum.From what I read on the jag and RRS forums (it’s a popular upgrade for them too) the B is the important part, the last letter is believed to be software version
thats a bonus, see if they will let you snip the power connector out with the module 😉 oh and maybe practice on side panel removal 😂Thanks, that is great I have now just found this on the Jaguar forum.
DAB modules are 6H52-19C032-Ax
DAB+ modules are CPLA-14F720-Bx
The x can be many different letters depending on the module revision...
Good news is there is one in the breakers less than 1 mile from my house, it will have to be done![]()
Is this the only wiring part required to wire the new unit up - LR032814? Thank youit’s just a case of 3 plugs and 2 bolts to swap the module View attachment 7078
There maybe be an official guide to removal of the boot side panel but other than the 2 bolts for the luggage ties it’s basically just clipped in place, you just need to unclip it all the way round and slide it over the seat hook to get it out the way...
The dab module is sat just below the right side boot window, you need to remove the 2 floor luggage tie downs and then fold the rear seat down, pop the interior light out and unplug it and then use a trim clip tool to aid removal of the whole side trim panel, once this has been pulled out the way you will see the module, held down by 2 bolts.
The part numbers for the dab+ module I used and power supply connector adaptor are
CPLA-14F720-BP (module)
LR032814 (power connector adaptor)
Looks like it from jonnybgud's postIs this the only wiring part required to wire the new unit up - LR032814? Thank you
