Timing chain failure petrol Evoque
6.1K views 6 replies 5 participants last post by  Wak123
If it happened at high speed Its likely you've almost certainly bent every valve, and may have damaged rockers and even pistons.
I had a timing belt go years ago ond an old car, I rebuilt the head myself with new valves, but it never ran quite right again.
Might be worth finding someone who will rebuild it to get it running again, but as Binty says, keep in mind you can pickup a decent 2013 model for something around ÂŁ15000... may be a better option than replacing/rebuilding your engine.
Reactions: Wak123
