Timing chain, not belt. It's located at the back of the engine, so the gearbox has the come off to get to it.Oldgit said:So does anyone have any idea what the ingenium engine has?
Sounds like an expensive operation to replace a warn chain.AndyM said:Timing chain, not belt. It's located at the back of the engine, so the gearbox has the come off to get to it.Oldgit said:So does anyone have any idea what the ingenium engine has?
Thanks Andy. Good job I don't do high mileage these days!!
Iirc it's 7 years or 112000 miles, whichever comes firstIt's a belt - Land Rover changed the intervals from 10 to 7 years (not sure about mileage), but yours definitely needs doing.
The parts usually come as a kit with water pump and idlers. Often you can't see any wear on the parts, but that doesn't mean you shouldn't change them.
I would get it changed myself for piece of mind as it’s due and you don’t know when last owner had it done. Timing belt kits come with the belt, tensioners and water pump and I would also change the crankshaft pulley bolt and alternator belt whilst you are at it. The coolant will also need changing.Was going to start a new thread but saw this thread and thought I'd ask on here.
I've got a 2011 dynamic lux 2.2 diesel automatic. Does anyone know if it has a chain or a belt?
As it's 10 years old now and done over 134,000 miles I'm a bit worried as I haven't any paperwork to say it's had its timing belt changed.
Should I get it done (or anything else important)? Could my mechanic maybe tell by looking at it if it looked old and worn? Also any idea of how much a replacement would be and where to buy from?
Cheers in advance....Malita!
i would get this done before anything else on the car for piece of mind.Thank you so much guys! Will definitely look into getting this done as soon as financially possible.![]()
