1 - 3 of 3 Posts
Unfortunately I have to install a marten defence unit under the bonnet.
To start it as the car is parked and shut it down when riding, I need to connect it to a terminal 15 wire/connector.
Where can I find this under the bonnet?
Thanks!
One assumes what you are looking for is a permanent Live and GND so the device is always on (Assumes it has auto shutoff voltage), No idea what terminal 15 means... maybe Fuse 15?, there is a fusebox in the engine bay, Gnd will be easy, any bolt on the bodywork.
If this is just for in the garage, maybe get a 12V supply and connect it externally to the Car, to save your battery.
Agree with PhilSkill, connect unit externally from a separate 12v supply / spare battery to reduce drain on vehicle battery... good luck with eradicating the critters ...
1 - 3 of 3 Posts
