I consider to order a Prestige, Fuji White, Spirit interior with Tech pack and Auto. I am not sure to go for a TD4 or SD4. Anybody with some advice? Is it worth the extra money. What about the story a different exhaust. Thanks!
If you need theAdaptive
Dynamics then you need to go for the SD4 otherwise I should select the TD4. The TD4 engine is great.
If you get the TD4 in Dynamic, you get twin exhausts regardless of engine choice. The only way to spot a Dynamic with TD4 engine, is on a cold morning you'll only see 'steam' coming out of one exhaust tip not two.
Seems that the spec is different overseas, UK models don't give you TD4 in Dynamic.Anyone know how this is ?
Apparently the UK doesn't let you get TD4 in automatic either.
I don't get why car manufacturers do this. I can understand for small markets/countries- offer fewer models to keep it simple, but the UK hardly counts as this! Heck - the Evoques are build there after all. Even the US folk can only buy their Evoques with the SI4 engine - no diesel whatsoever?!
Whatever the reason, I'm thankful that the Australian market allows for every engine/spec combination possible. Otherwise I would have been forced to get SD4 to get my Dynamic.
