1 - 13 of 13 Posts
As I bought a 2020 demo I didn’t get chance to order the high beam assist, I want to get this coded but dealer I bought from says it’s only possible on the signature headlights.
Looking at the configurator it says you can add HBA to the standard LED headlights
Like mine.
Has anyone with the above headlights added the high beam assist from factory options list ?
Thanks in advance 👍
Discussion Starter #2
Just found this on the New configurator, so not sure why they say it’s only on the fancy headlights
Mine has AHBA and they’re not the matrix ones, but I think they’re a bit different to yours 🤔
Yes I think you have the signature ones
Mine just had the bottom strip lit.
Land Rover say I need the ones like yours to add HBA but when I bought it a year ago the configurator said you can add it to standard LED ones
Mine are just the standard LED
I’ve got LED headlights on my Jag, useless compared to the Evoque I had.
Mine are pretty good but miss the assist part as my last car had this.
@DKZ5745 do you have a menu for this in lighting
Yes, mine are the ones on the right.
I will have a check next time for you. I don’t think I’ve messed with anything in the headlight settings, but the auto high beam is pretty amazing, although I was a little confused the first time, especially when it dipped again due to oncoming traffic.
Thanks that would be a massive help, also the directional indicators are in the same menu do you choose front and rear or is it both
Thanks again
Discussion Starter #11
Thanks for the reply, do you have the standard LEDs or the signature type
Discussion Starter #13
Ok thank you, I’ll keep searching 👍
1 - 13 of 13 Posts
