1 - 5 of 5 Posts
My evogue has a fault code that says rear right wheel speed sensor fault...
Abs, brake, and some other light are on the dashboard...
Please what can be the problem?
2012 Evoque, i just replaced the rear right sensor and still the problem is still there..
After scanning after replacement it still inducating that rear right speed sensor fault.. Thanks for you quick response!
Check the wiring to the sensor for damage, and the connector at the top of the wheel well, It could also be corrosion or dirt on the Trigger ring (the castellated part of the rotating hub that the sensor sits close to.)
3819
Thanks phil..... I will do just that right away..
But phil can you get the diagram of the two wire on the ABS for me too locate easily.?
The ABS is hidden behind the battery and it will be very difficult too check the wires one after the other..... So if i can identify the two wires it will be easier for me too solve... Thank you!
1 - 5 of 5 Posts
