1 - 20 of 30 Posts
Hi all, newbie to the forum.
Looking for for help with my reverse camera for my 2015 evoque dynamic SD4.
Got an alarm on the dash ‘camera system fault’ last week. Took the camera out and opened it up to find it’s badly corroded inside. I reckon the camera is knackered so
I purchased a new one from eBay. Just tried to connect the new one today but won’t go together due to there being a very slight difference in the plugs. I’ve read things hear and there about being differences in these cameras. I can’t seem to source a camera which has the same plug as my original. Has anyone had this problem?
Thanks,
Paul
Thanks,
Paul
Sorry I cant help but there was something about the differences a while back on the forums. I’m sure if you look back you’ll find it or failing that someone will be along to help :smile_big:
Thanks,
Paul
I take it that you took the part number printed on your faulty camera?
Thanks for the help guys!
Yeah it’s GJ32-19G590-BC, I can’t find any with that similar code. They all seem to start with either FW93 or CPLA. These ones don’t seem to fit as the plugs are ever so slightly different.
Makes sense as there are 2 cameras for the 2015 model.
This is possibly down to the fact that LR had issues in 2015/16 with cameras fogging up and replaced them with a newer version.
Wasn’t aware the fitting was different though.
As a short term fix some were fitted with an outside casing with 2 holes drilled in the bezel to allow airfow.
This was then changed to a proper camera housing once issue was sorted.
So it may not be worth replacing with a like for like as that could be replacing a bad camera with another bad camera Pre issue being resolved and could possibly go again.
If it were me, I’d be popping it back to LR dealer for a price....don’t replace dodgy camera with another dodgy camera.....
I'd be popping back to dealer and asking for a bit of good will outside of warranty seeing as fogging cameras was a known issue
Did you get anywhere with LR? I have the same problem with a 2015 model with camera GJ32-19G590. I tried to fit the other camera but as stated it has a slightly different fitting.
Read Only
I’m working in hospital at mo just on quick break but I’m sure Sadie has a thread about 3 weeks ago similar problem if you can’t find it I’m sure someone will be along shortly if not I will look later😁
Reactions: DKZ5745
That one Donna ?
Reactions: 9492
Doh! XZ4 quicker on the draw than me AGAIN !!!! 😂
Reactions: 9492 and XZ4
I’ve been looking back through too! 😀
Reactions: 9492
We actually picked different threads anyway, just realised 😁
Reactions: 9492
Read Only
Thanks guys can’t check ...busy girl and some of the rooms I’m in are coated with lead so signal not great 😂😂😜
I have a helmet like that, so the government can’t see what I’m thinking 🤔
1 - 20 of 30 Posts
