2015 SD4 Dynamic 78k... Travelling on the M6 today in Cruise Control at 70 mph. The above message appeared without any loss in speed, but lack of power on acceleration (limp mode I believe). Probably about half hour into my journey from cold. The time for maintenance reminder has been flashing up for about 3 weeks now if any relevance. Anyone else experienced this pls?
Happened to my 2015 Sd4 Dynamic Lux 47K a few months ago turned out to be the turbo which was replaced under warranty.
I had that message years ago and it was the EGR valve that was replaced under warranty.
Good luck getting it sorted.
The "Service Required" indicator should not cause any problem like this.
Thanks for your replies folks. It turned out to be an emissions issue from a high reading from a sensor on the exhaust system. The code was re-set, I had it serviced & no repeat issues since
Sounds a bit fishy to me, wait for the next message to arrive. Best to keep a diary of this, you may need it when / if the problem reoccurs. :unsure: :unsure:
