1 - 3 of 3 Posts
Does anyone know if there is anything special about removing the rear spoiler - it looks easy enough just remove the bolts and I presume unplug the antenna connector?
Thanks,
Peter.
I looked at this sometime ago and am pretty sure that there's wiring looped through the spoiler (high level brake light at least) - think the connectors are under the headliner, so not that simple.
@Peter Henry It's worth updating your forum profile with your Evoque year and spec so people can see what vehicle you have :)
I see you have a couple of threads on 'brake sensors' - it would be good if you got to the bottom of this to update those threads in case it helps others.
1 - 3 of 3 Posts
