1 - 10 of 10 Posts
SD4
Hi guys ! Was wondering if anyone knew the exact type of could link me to the correct bulb that goes above the rear passenger heads next to the coat hanger holders :)
2014 SD4
The Year of your Evoque might help...
Reactions: CoolBlueWhyte
In that case they should be T10. Just google T10 LED.
Note the covers can be a pain to get out be very careful not to damage anything as you have to pry from the side with something thin and plastic.
Automotive design Motor vehicle Font Automotive exterior Auto part
As PhilSkill says, any variation of T10 although I found that a shorter type lamp fitted better due to the chrome reflector.
Take a look at PowerfulUK's video for advice.
BTW, they move onto the rear lights at c. 4 mins 45 secs into the video 👍🏻
Reactions: PhilSkill
Useful Video, but Blue LED's with a Red Trim Interior...
No accounting for taste!
Think his jumpers say it all! 😂
From experience, if you're thinking of changing the front centre courtesy lights, these are really fiddly & will bring on a tourets episode. My advice is to go for a longer type T10 lamps to give you something to keep a grip on as you're trying to locate them in the holder.
FYI the space for the lamps inside both front & rear units isn't really that compromised so most length lamps will fit in either.
And Dont forget the courtesy Light can get themselves turned off when messing about with the covers, I think its long hold for 10 secs or more to reset!
1 - 10 of 10 Posts
