AutoExpress have put up an off-road review of the Evoque:
The furthest most Range Rover Evoque buyers are ever likely to venture off-road is the overflow car park at the races. But the 4x4 offers the go-anywhere capability you would expect from a vehicle wearing the legendary badge. How do we know this? Because we've given our Car of the Year 2011 its ultimate off-road test.
While the Evoque can be specified with front-wheel drive, most buyers will opt for 4WD. This uses the Freelander's Haldex system, which shuffles torque between the front and rear axles to ensure power is sent where it's needed most.
All four-wheel-drive Evoques are equipped with Land Rover's excellent Terrain Response system ""“ although, unlike on other models in the range, it's operated by pressing a button rather than turning a dial.
The set-up gives owners a choice of three off-road modes: gravel/grass, muddy ruts and sand. Each adjusts the sensitivity of the ESP system, as well as the settings of the all-wheel drive, throttle and automatic box.
The electronics also alter the weight and sensitivity of the steering for greater control and precision, and to reduce the risk of the wheel being ripped from your hands if you hit a rut.
All this means novices can tackle the trickiest of obstacles. Yet the most confidence-inspiring gadget is Land Rover's renowned Hill Descent Control set-up, which leaves you to steer while the car deals with any steep terrain.
You may think the Evoque's go-anywhere credentials would be compromised in this sportiest model in the range. However, it's more capable over the rough stuff than the current Freelander. This is thanks to its higher ground clearance, shorter front and rear overhangs and lower kerbweight
Read more: http://www.autoexpress.co.uk/carreviews/firstdrives/271663/range_rover_evoque_offroad.html
Cheers
Dan
Cheers
Dan
