1 - 3 of 3 Posts
Hi
My partners 2016 facelift Evoque as has had some strange central locking issues over the last few weeks. It was mainly where the drivers door wouldnt lock and the wing mirrors didnt fold in. I did a bit of reading up on this marvellous forum and decided it was worth fitting a drivers side door mechanism. I asked a local LR specialist to fit the genuine LR part and its sorted the issues out... for about 2 days. So now we have the same situation but more often than not, the whole car will not lock or unlock including the boot. Ive replaced both the batteries in both of the remote controls as well.
Has any of you guys had any similar issues, or know how to resolve or what to try next? Does the Central Locking ECU register faults if any occur?
Thanks for your help.
Chris
Hi and welcome to the forum.
You might like to let this other new user know where you got your part from as he's having problems:
RHD Right Front Actuator
I've never heard of people having to reset codes for this. I would guess the newly replaced part needs looking at/tweaking.
Have you contacted the LR specialist to see what they say?
When you lock the doors, are you able to open all of them when you use the handle or is it just one that's playing up?
That is a strange problem. The replacement actuators usually resolve the problem without any complicated resetting.
As suggested, ask your specialist to fault find the issue as it’s clearly not straightforward.
1 - 3 of 3 Posts
