1 - 20 of 20 Posts
2013 SD4 Dynamic Lux
Both front and rear sensors aren't working, neither is park assist (probably due to sensors not working?)
Awaiting delivery of the manual so could someone let me know if it might be a fuse problem, and which fuse it is please?
Thank you
Stupid reply from me, but how do I tell? Starts first time with no issues, should I go on a long run as it's come straight from dealer on low loader??
I would as there are lots of posts of people having what you would expect to be unrelated battery problems due to this.
Give it a go or stick it on charge and see what happens.
If it still has its original battery fitted then it might be time for a change anyway, get the dealer to do it as the battery monitoring system will need to be updated after a battery change!
We are all here to help each other when questions arise.
Does the Parking Sensor Button light flash a light when you try to select it? If so a parking sensor is faulty, or a connection is dirty/wet. If you've just recieved it then check all the sensors are clear and clean, otherwise might be better taking back while you have some warranty.
Discussion Starter #12
Just returned from local indy, there are 31 faults across 16 modules with 9 modules not responding, so I've emailed the dealer formally rejecting the car, only had it 6 days.
Wow, that sounds serious, but let's hope it's something minor causing a waterfall of knock-on indications, if you want to reject then it sounds like you'd be well within your rights doing so. Good luck either way.
These are the modules affected:
ABS CONTROL, ACTIVE DAMPING CONTROL, BODY CONTROL, DRIVERS DOOR, PREMIUM FRONT CONTROLS INTERFACE, HEADLAMP CONTROL,REMOTE CLIMATE CONTROL (HVAC), INSTRUMENT CLUSTER CONTROL, REMOTE FUNCTION ACTUATOR, PARKING AID CONTROL, PARKING BRAKE, POWERTRAIN CONTROL, PASSENGER DOOR CONTROL, POWER STEERING CONTROL,, RESTRAINTS CONTROL, REAR GATE/TRUNK - then 9 others not fitted or not communicating!!
But apart from that, is it a nice car ?
Reactions: Maffy
1 - 20 of 20 Posts
