1 - 11 of 11 Posts
2015 HSE Dynamic automatic
My left can be adjusted and moved but won’t fold in like the driver side one does.
Any advice?
Have you tried switching them off and then back on again?
Reactions: _Ben_
Is the door with the faulty mirror locking ?
Reactions: _Ben_
Discussion Starter · #4 ·
You mean pressing to force them both closed like you’re going through a narrow gap? I’ve tried that and only 1 goes in. Or is there something else?
MY20.5 R-Dynamic HSE
By pressing the 2 buttons just above the 4 electric window buttons, pres and hold both buttons together
Reactions: _Ben_
Discussion Starter · #6 ·
When I press and hold both buttons only the driver side one goes in.
Have you tried manually folding the faulty mirror in while the car is locked and then unlocking the car to see if it unfolds?
Reactions: _Ben_
Discussion Starter · #9 ·
No I haven't. Thanks for the tip. Will report back!
Discussion Starter · #10 · (Edited)
I did it manually but it would not go back either by unlocking or pressing the buttons. Had to put it back manually.
I recall that you can turn the folding mirrors on and off on the dash menu on the steering wheel. But I may be wrong!
if you can, then try turning them off and back on to see if the offending one resets🤞
1 - 11 of 11 Posts
