21 - 21 of 21 Posts
2018 Range Rover Evoque SE Tech TD4 Auto Cirrus Gray
When the engine is running oil will be sprayed around and over the dipstrick.
It's been the case since I watched my Dad doing his cars that you should run the car up to temp, park on a flat area and wait 10 minutes.
Always wipe the stick after first removing it then fully pop it back in then remove for an accurate reading.
Spot on PhilB. I was told this procedure to check your oil level away back in the early 70’s 👍
21 - 21 of 21 Posts
