1 - 20 of 31 Posts
Having looked on the Topix site for details of my car, it states that the 'Surround Camera System' is fitted but I can only find the reversing camera, is this a common thing? to have it showing on Topix but not really present...or could it be hiding somewhere?
As far as I can see on the configurator the 360 cameras aren't an option on the First Edition
It was never suggested that they were fitted when I purchased the vehicle, but when I saw it was listed in the spec sheet on Topix I thought it was worth asking the question.
.......and when I press the camera symbol while viewing the rear camera i get a slightly different downward angle of the rear camera image.
Does it show "Less" in front of it? LR have a strange way of showing what a vehicle hasn't got.
Just checking :)
  • 2-ZONE CLIMATE CONTROL
  • ALL TERRAIN PROGRESS CONTROL
  • ALL WHEEL DRIVE
  • AMBIENT LIGHTING-CONFIGURABLE
  • AUTO TERRAIN RESPONSE
  • AUTOMATIC HEADLAMP LEVELLING
  • BBU WITH TILT SENSOR
  • BLACK PAINTED ROOF
  • BLIND SPOT ASSIST
  • BONNET LOUVRE-BURNISHED COPPER
  • BRANDED SOUND SYS (L3)
  • BUMPERS-SPORTY (BDY COLOUR)
  • DIESEL EU6D-TEMP EMISSION
  • DIGITAL AUDIO BROADCAST
  • DISC BRAKE SIZE FRT 18/RR 16
  • DR ARMREST-PVC
  • DR TRIM PNL-TPO/PVC
  • DRIVER SEAT - STANDARD
  • DRV/PAS ELEC FT SEAT MEMORY
  • EBONY HEADLINER
  • EFFICIENT DRIVELINE
  • ENGINE POWER SOURCE - 180/430
  • EURO/RUSS 3YR CONN SERVICE PK
  • EXT MIRROR FINISH -BLACK GLOSS
  • FOOT PEDAL - METALIC FINISH
  • FRONT FOG LAMPS
  • FRONT HEADREST MANUAL HEIGHT
  • FRONT SEAT LUMBAR - 4 WAY
  • FRONT SPRING LOAD CLASS-G
  • FRONT STABILISER BAR CLASS B
  • FULL TFT/LCD INSTR CLUSTER
  • GRILLE-DARK ATLAS
  • H7 BATTERY
  • HALEWOOD
  • HEAD UP DISPLAY
  • HEADLAMP POWER WASH
  • HEADLINING - MORZINE
  • HEADRESTRAINT-REAR CENTER
  • HEATED FRONT WINDSCREEN
  • HEATED SEATS - DRV/PASS
  • HEATED STEERING WHEELS
  • HEATED WASHER JETS-W'SHIELD
  • HTD/P-FOLD/MEM/A-DIM/APP.LIGHT
  • INCONTROL APPS
  • IP-PVC
  • KEYLESS ENTRY/START-PASSIVE
  • LEATHER GEAR SHIFT KNOB
  • LOCKING WHEEL LUG NUT
  • MAPCARE - EURO/RUSS 3YR
  • MATIX LED, SIGNATURE ADB
  • NAV REG 1 EUROPE
  • NAVIGATION CENTER
  • PADDLE SHIFT - BLACK
  • PERIMETER /VOLUME THEFT SYSTEM
  • PIRELLI TYRE VENDOR
  • POWER BASE
  • PRO SERVICES AND WI-FI HOTSPOT
  • PTC HEATER
  • REAR SEAT CENTER ARMREST
  • REAR SPRING LOAD CLASS-F
  • REVERSE TRAFFIC DETECTION
  • ROOF - FIXED PANORAMIC
  • SEAT CUSHION POWER FORE/AFT
  • SEAT CUSHION POWER HEIGHT
  • SEAT CUSHION POWER TILT
  • SEAT SQUAB POWER RECLINE
  • SIDE VENTS-BURNISHED COPPER
  • SOS/ASSISTANCE CALL
  • STABILISER BAR REAR - CLASS D
  • STNG WHL - LEATHER/CHROME
  • STRG COL-POWER ADJ W/O PYRO
  • SURROUND CAMERA SYSTEM
  • TAILGATE/BOOTLID-POWERED
  • TCU MODULE - ROW
  • TRIM LEVEL 4
  • TSR/ADAPTIVE SPEED LIMITER
  • TYRE PRESSURE MONITORING SYSTM
  • TYRE REPAIR SYSTEM(IMS)-HIGH
  • UNITED KINGDOM
  • VOICE ACTIVATED CONTROLS
  • LESS ADAPTIVE DAMPING(PASSIVE)
  • LESS AIR PURIFIER SENSOR
  • LESS AIR QUALITY
  • LESS AUTO HIGH BEAM ASSIST
  • LESS CARGO NET KIT
  • LESS CONFIGURABLE DRIVER MODES
  • LESS DERIVATIVE BADGE
  • LESS ENGINE BLOCK HEATER
  • LESS FRONT HEADREST WINGED
  • LESS FRONT SEAT BOLSTER
  • LESS FRONT SEAT SQUAB ARTICULA
  • LESS FUEL/POWER/DRIVE BADGE
  • LESS GARAGE DOOR OPENER
  • LESS LEISURE ACTIVITY KEY
  • LESS LOADSPACE STOWAGE RAILS
  • LESS REAR ENTERTAINMENT SCREEN
  • LESS REAR SEAT HEATING
  • LESS REAR SEAT RECLINE
  • LESS SEAT CUSHION EXTENSION
  • LESS SEAT MASSAGE FRONT
  • LESS SMOKERS PACK
  • LESS SPECIAL VALUE PACKAGES
  • LESS TOWING EQUIPMENT
  • LESS TRAILER HITCH GUIDE
  • LESS TV RECEIVER
  • LESS VEHICLE INF CONTRL SYSTEM
  • LESS WATER WADING AID
MY15 Dynamic Lux has a "Surround Camera System" Listed & it is fitted & working, so I would think that yours should be also.
Discussion Starter #11
When I receive my V5 doc for the car I'll take it to a local Land Rover dealership to have the InControl registration changed and will mention it to them.
Probably the best idea, but don't expect an answer that makes sense first time. :unsure:
Discussion Starter #13
Are there any pics available of what and where these external cameras are, then at least I can see if they're actually fitted or not?
Haven't got any pics but you have the rear one under the boot lid, front in the centre of the lower grille and one under each wing mirror.
If you press the camera icon when stationary with the engine running you should get a diagram on the screen to be able to select cameras for things like junction view and also a downward view of the sides of the car so you can keep your wheels away from kerbs etc.
You should have one on the tailgate above number plate(to the right viewed from the rear) one on the bottom of each side mirror & one each side on the front bumper. If you follow the lower black trim from the front wheel just to the right where the red wing joins the black lower grill you will see the small round lens of the camera, same on other side. Total 5. (y)
Sorry to disagree Bazz but I've just checked mine (Mk2) and there are only four cameras.
Whilliam also has a Mk2.
Discussion Starter #18
I've just had a quick look at the car and I can only see the reversing camera with what looks to be a wash jet next to it, at the front of the car I can see 3 black parking sensors (probably) set into the lower black grill and a small black panel also set into the lower black grill, drivers side.
No obvious front or door mirror cameras seen.
Looks like it doesn't actually have the 360 cameras.
You can check on the configurator to see if they are standard on the First Edition.
If you press the camera icon on the main screen, then if you have the 360 cameras you should get a screen like this:
Discussion Starter #20
When I press the camera icon i get the No. 1 & 2 image as per your pic but without the camera locations image shown on the left. I hoped it might just be a software problem but looks like they were never fitted, I'll still ask the dealer though.
Thanks to all for contributions.
1 - 20 of 31 Posts
