1 - 20 of 21 Posts
Hi all
I'm four weeks into ownership of a brand new P250 Evoque and am curious as to whether these vehicles are sensitive to the effects of road camber. I noticed the steering was very slightly off centre when I took delivery of the car but put it down to the severe camber on the country roads where I live. However, I've just done a 150 mile trip which was mainly motorways and the issue is still there. For example, when driving on a flat stretch of the M1 in the outside lane, if I straightened the steering wheel, it definitely steered slightly to the left. Does anyone know if this is normal and are these vehicles set up to allow for camber (hope that makes sense!)? Or should I be referring this back to the dealer to get them to check the wheel alignment?
Any comments would be appreciated.
Definitely not normal.
I've found the steering is really good.
Doesn't follow the camber of roads at all.
With all the bad weather recently even going through big puddles has no tug on the wheel.
I'd take it back to the dealer as it's just not right.
Get them to check the tracking also in case someone has whacked it on delivery or PDI throwing it out of alignment.
Thanks Phil. I needed someone to confirm it wasn't just me. Cheers for that.
Yes I would agree. Sounds like low tyre pressure or tracking. I had a BMW like that, but a 4 wheel alignment made it feel like a different car again.
Does this after just 4 weeks of brand new ownership---LR hang your heads in shame-rapidly being overtaken by the likes od Hyundai and Kia-at least they stand by their LONG warranties!
Get a grip or we will be seeing headlines along the line "we are sorry to announce the closure of a iconic british brand " "all production is being moved to Islamabad and Moldovia" etc etc etc
Play merry Hell with them-what happened to thorough PDI?
I have mine set to keep me in the lane. On cruise control I can let it steer itself, though if I take my hands of the wheel too long it gives me a message not to!
Reactions: Jam911
Should you be driving at your age ? ???
Reactions: Maffy
Hi all
Mine does exactly the same... would go a little left if wheel wasn’t straight. Looks like I’ll be booking mine in as well...
I think the problem is that his steering wheel isn't set in the straight ahead position.
If yours is tracking straight when the wheel is straight then it sounds ok.
Try driving in a straight line with your finger and thumbs gently holding the wheel and feel for any pull to either side on a flat road.
2015 Dynamic Lux 2.2Sd4
:mad: ? Hi dirtyharry, that is definately NOT right, if it was me I would the dealer would have a flea in the ear by now & not be in any doubt that there was a problem.?:mad: As Maffy said no PDI carried out????
No, I have the same issue as the OP - I just worded my response wrongly... with the steering wheel straight ahead, my car tracks a bit left.
No tracking problems on ours, stays straight for as long as any other modern car we have owned.
Hi all
Mine (also a brand new P250) does the same! It also steers slightly to the left. I thought it was normal - due to slight camber we have on most of our roads in Switzerland (it ain't flat around here). It does it even on highways. My previous car did the same, so I thought it was normal.
Still doesn't sound right to me. I would deffo get it checked out ASAP, before you wear the tyres.
So I tested this morning on the highway and it seems that what I perceived as a problem is no longer there. As my Evoque was at the dealership last week for another issue, I guess they might have fixed that as well...
Maybe they monitor this forum???? & spotted their deliberate mistake :) ;) :unsure:
Reactions: macounette
1 - 20 of 21 Posts
