1 - 20 of 27 Posts
Good price, I paid £250 for drilled Brembos and pads for rear last week
Looking good. Hope you can get those stains off the block paving!
Reactions: ukcommander
Funny was thinking the same thing Vet!
Looks good though, I have a new set of OEM brembos ready to go on mine... although haven't used it much at all in the last 4 months so may go a bit longer.
Don’t these cars seem to have tiny discs compared to the size of the wheel?
Its only WD40 so will soon come off when I get round to the 5 year jet wash. ☺
Yeah unreal that a 2 tonne vehicle has 300mm discs and 302mm on the backs.
All down to the pistons and pressure of the pads
Same size wheels on my F Type but bigger brakes 380mm
5784
Nice job on the brake pads might let you do mine if you’re passing, will have to get a dust sheet for Monoblock though .... can’t be giving wd40 a bad name now😂😂😂
Discussion Starter #13
Ha ha, I think im a seasoned professional now with brake discs and pads. It took me about 3 hours all into do the evoque because everything decided to be extremely tight so that's why some much WD40 was needed.
MY20 P300e PHEV | Yulong White | R-Dynamic SE | Panoramic Roof | Clearsight | Driver Assist Pack
Do the discs increase in diameter as the engine size/bhp increases on the Evoque? I assume they do.
The P330e has 349mm on the front and 325mm on the rear
Discussion Starter #15
I know that the the 2.2td has 300mm fronts and 302mm rears. I think the only bigger ones are the petrol models which get 325mm fronts. Still not a big upgrade for the size and weight of the vehicle.
The question is how big to they need to be these days, my wife’s car is a 6L V12 and I’m sure her fronts are only 355 or 365 dia...they’re ruddy expensive I know that!
My 5.7L Hemi only had 330mm dia and that was way over 2t and 5m long....it did take almost a week to come to a standstill tho.
Caliper piston power and pad material must be a big factor in braking power and not just the disc.
Those discs don’t look like they’ve been used yet...either you coast all day long or forget to brake...or both 👍✊👌
Braking is for wimps 😎
Here Here @DKZ5745 ...well said 👍
Reactions: DKZ5745
They've been in the car since I got it 2 years ago but I've only done about 5500 miles . No idea when they went on though. I use engine breaking a lot so I'm not hard on brakes😀
1 - 20 of 27 Posts
