I have an odd problem. When I get in the car and set the seat heater to 3 it heats up as expected. I then turn it down to 1 and the temp goes down but after about an hour it starts to get hotter again. Even if I then turn it off it still stays hot. Anybody else experienced this?
The seats tend to heat up and cool down and will stay hot for a while after turning them off.
It's a "feature" on other JLR vehicles as well.
On first putting them on 2 on mine you can get a burnt arse situation until after about 5 minutes they cool down and keep a good temperature.
I just use setting 1, (great for my back ), keep heating up/cooling.
Yes I have this too, after switching off they still keep heating, is it because outside temp is low?
I just put mine on 3 & leave it there until it鈥檚 hot enough & turn it off. Heat drops str8 away and stays off (2019 Jaguar F Pace though)
I usually put mine on 1, too, unless it's freezing outside as it was a couple weeks ago - then turn it back to 1 - takes a while for heat to wind down.
