1 - 2 of 2 Posts
Hello
Even though I'm not getting delivery until June, my excitement is already taking over and I keep thinking of questions. Hopefully some of you lucky ones who already have the car will be able to answer....
1. Keyless entry: What is the range for this to work? Does the car auto-lock after a certain period of time (engine off).
2. Dual screen TV: Is this viewable to rear passengers?
3. Powered tailgate: Is this literally just that you can open the book from the remote, or is there a button you press to close also (I have seen this on BMWs)?
4. When you go on the Uk configurator, and look at the Lux pack detail - it says it includes "Climate control - automatic with air filtration and air quality sensing for automatic recirculation"...... what is the difference between this and the standard climate control (or isn't there any?!)?
Thanks!
Adam
On your powered tailgate question. Button on keyfob remotely opens, if pressed again it stops it from opening any further. You need to press the button on the inner bootlid lip to close it.
1 - 2 of 2 Posts
