1 - 13 of 13 Posts
MY20 P300e PHEV | Yulong White | R-Dynamic SE | Panoramic Roof | Clearsight | Driver Assist Pack
All,
I have a private and a work mobile phone.
The question I have is...can I pair both phones into MY20 Evoque with the Pro Duo?
Secondly, can I answer whichever phone rings via hands free or does the Evoque have a default phone as such that stops me from answering my second phone if it were to ring later?
I think I’m making sense here 🤷‍♂️
I suppose if you can’t you could divert one of the phones to the other ?
Reactions: ukcommander
I used to do that on a 5 Series a few years back, it’s annoying but a simple fix. My X3 of recent with the expensive ‘more than one’ phone pack used to select whichever phone rang so it wasn’t a problem having 2 phones. Two be honest, it’s safer not even answering the phone these days!
When other half is in car I have to select which phone to connect to Bluetooth ... so think only one on mine but it’s the older system.....
Mine is still only one phone, would be convenient if they did allow for two in the MY20 cars
Especially when you can pair up to 10 devices on the Pro Duo apparently.
Reactions: Doink
Both mine & my wife‘s iPhones are connected, but as far as I know only 1pairs at a time. Not 100% sure, cos I can’t remember having a call in the car when she was in with me, but I think it defaults to the last user. I may be wrong 🤔
Thanks, I think it will default to the last user or they would mention otherwise as a feature in their glossy pamphlet.
If you load both phones the system will pick up on whichever it detects first.
So, does that mean I get into the car with 1st phone, let it auto pair and then go back inside the house and get the 2nd phone. 😂
Whatever floats your boat-or take them both but with one switched off-the possibilities are endless to be honest!!!
You can connect multiple devices simultaneously (e.g. audio through one, another for calls) but can only use one at a time with the phone function.
Discussion Starter #13
Thank you Ernesto 👍
1 - 13 of 13 Posts
