Hi all,
After not much use for the past few weeks my Evoque struggled to start with a dead battery, which I temporaily restored via a jumpstart. Unfortunately, I’ve noticed some issues which I’m hoping some members can help with?
1. Mislocking - my car no longer fully locks with the 2 beep sound and the wing mirrors do not fold in. I’ve determined the rear doors are no longer locking when using the key fob. Is this related to having a dead battery or the locking mechanism?
2. Rear windows no longer open - do the windows need to be re-calibrated after a dead battery? Holding up the window switch for 6 seconds does not work for me. Front windows work fine.
3. Battery charging - I know this gets debated a lot but is it advisable to charge the battery while it’s still connected to the vehicle? should I connect the negative to the negative terminal on the battery or to the negative earth point nut on the other side of the engine bay? I already own a Ctek MXS 7.0 so would like to charge the battery.
Any advice would be appreciated.
