1 - 8 of 8 Posts
Hi all,
I bought a 3 door evoque back in August. Had nothing but problems with it. First the cruise control had a fault , then the power rack went. Have just got it back after spending 6 wks in the garage.
Now the boot is leaking really badly.Not sure where it is coming from. I phoned the JLR dealership who have said they want £198 for a diagnostic check. Should I take it there or should a go to a local garage. My car is a 2014 plate so I doubt this would be covered under any warranty ( do have an extended warranty for the garage I bought it from). What do you guys think ? Any advice is gladly welcome. Thanks.
Hi and welcome. I would take it back to the garage you bought it from and get them to fix the leaking boot.
Read Only
I’d take it back too... was steering rack fixed for free under warranty ... it should of been
Discussion Starter · #4 ·
yes, steering rack was replaced under the extended warranty that I got from the garage. They ended up having it for 6weeks. Will give them a call tomorrow, it’s annoying as the garage is an hour away 😢
Discussion Starter · #6 ·
Yes I have a panoramic roof. It seems to be coming in through the side vent where the parcel shelf sits.
Read Only
Maybe a rubber seal above boot door or window or a leak in panoramic roof that’s running down rear pillars ? Not heard this one before ... I don’t see how a diagnostic test will help ...
1 - 8 of 8 Posts
