Delivery pressures - helps avoid flat spots if stood too long. Should have been changed at PDI as you say.Hello all .... just thought I would check my tyre pressures today .. so should be 37psi on the front and 35psi on the rear
what did I have ...
52psi all round .. really, did they actually do anything on the PDI ???
I am presuming you have the Scorpion Zero as factory fit ?just quick question .. do any of you put winter tyres on in the winter ??
hi phil ... yes Scorpion Zero you are correctI am presuming you have the Scorpion Zero as factory fit ?
They are all season tyres and unless you are up north when you are regularly dealing with snow then I wouldn't bother.
Mine went through two winters down here in the South with no dramas at all.
My Merc does that. were all over the place when I bought it, even had 1 run flat & 1 ordinary on the front axle. When I challenged them on the PDI they insisted it had been done! Even the screen wipers sounded like they were running on a dry screen in the pouring rain. Got the tyre & wipers replaced for free.Hello all .... just thought I would check my tyre pressures today .. so should be 37psi on the front and 35psi on the rear
what did I have ...
