With JLR washing their hands of my Map update failure issue their update has caused, I was left needing to fix it myself.
Bit of research on the 2011-2016 Evoque Nav System, determines the Maps are stored in the IAM module.
This contains the CD player and the NAV system, and is where all the Audio and Dab and GPS connects up.
The IAM is a box module with a CD slot, so unsurprisingly it sits behind the upper front console where the CD player is.
So E-Bay £60 found an IAM similar spec number to mine although a little bit younger.
Removal of the console is very easy, Made even easier by Powerfuluk's video, you can see the IAM in this video (the silver box in the dash when the console is removed)
2 T20 screws in the storage area and the console lifts up from the rear, remove 2 (Manual) or 3 (Auto) Connectors before fully lifting. In my Manual its a bit more awkward if like me you couldn't be bothered to remove the gear knob (See a thread on that I did if you want to), but put it in 4th and the console will rotate 90 deg to gain access to the IAM.
Picture of the IAM in situ
2 more T20 screws and the IAM module pulls forward enough to Access the myriad of connector types, all of which have a tab you push in and then pull out the connector.
Reconnect the new, slide it back in carefully not crushing any wires. Reconnect the console and test.
No coding required, it took 4 mins for the GPS to locate it's new position, and hey presto My Nav is working again.
Now to test everything else incase this IAM had other issues...
Then... do I dare try to update!?!
