1 - 7 of 7 Posts
1 Join photobucket -http://photobucket.com/
2 Upload your photos to photobucket following the instructions on the site. It doesn't matter about the original resolution of your pictures and when it asks you which size, medium or large will do for this forum.
3 When your pics are successfully appearing in photobucket, you'll see a few boxes underneath - one of them will start with square brackets followed by an "IMG".
4 Left mouse click in the box that says IMG, and you'll get a notification saying "copied" under your mouse pointer.
5 Now go to the post you want to reply to, and click on "post reply" in the normal way.
6 Type a comment for your photo, press the "space bar", and then right mouse click, "paste" to paste the line containing IMG into the post window.
7 Make sure you have a square bracket at the start and end of the line containing "IMG" otherwise it won't work.
8 Click the "preview post" button and hey presto, your pics on here for us all to enjoy....
Note: for the moment you can't directly upload to the forum, however its on my to-do list
Discussion Starter #2
Or!
If your pictures are somewhere else, all you need is the URL to your picture, so something like www.yourwebsite.com/picture.jpg
In this case, click the green tree icon
, paste in the image address in the IMAGE URL box and click preview. Your image should appear in the preview window. Click OK to insert the image.
Has this changed?
I seem to recall being able to upload photos and attached files directly to the forum
Peter
Nothing has changed, but I believe that some newer browsers (IE9) may be slightly different.
Hmm...I use the latest Firefox: wonder if one of the updates was the cause?
Have to try other options....
Will report...
Moderator
I use photobucket and firefox, view and use this forum via Apple products.
I always use the link provided by photobucket to post photos, click on it and copy to relevant thread.
Since the direct upload option was introduced (I think around August 2012), I have been using that.
1 - 7 of 7 Posts
