1 - 3 of 3 Posts
On our MY16 we have an interesting intermittent problem which I think I have managed to determine how to make it happen. It is heater related which we tend to leave on auto at 21° which is fine. However due to the colder weather we have been using the 'Max' blower to clear the windscreen. After using that from start up the heater doesn't blow any hot air into the cabin. If we don't activate the 'Max' the heater works absolutely fine ......
Any ideas as to why this might happen ? TIA.
Max's brings the 'Air-Con' on, try turning that off.
We only put the air-con on in hot weather, it saves a small amount of fuel.
Our car has the electric heated screen.
Thanks Mike, sorry maybe my post wasn't clear. Even after turning Max off we can't get any heat out of the heater even on an hour long commute. However if we don't activate it first thing or via the app to clear the screen before getting in, the heater works fine. We also have a heated screen.
1 - 3 of 3 Posts
