1 - 2 of 2 Posts
Setting my ODB2 tool and my spare laptop (on win7 , I use Linux :) )up today on my Y2020 Evoque, with 1340 miles on the clock.
I looked at the DPF re-gens = 0
Type of Re-gen = 0
DPF set to trigger on = 100%
So do you think JLR have set the DPF NOT to re-gen because of all the previous problems ! , or as mine would surggest only when it is 100% full, with other info about the DPF it looks like it measures the differential pressure across the filter unit to trigger it to re-gen.
Any Of You With An ODB2 reader can you have a look what your car is doing and post please.
I'm guessing your OBD reader isn't compatible with MY20 so you aren't seeing correct information.
If the DPF doesn't regen then after a few 100 miles it will be blocked with soot.
1 - 2 of 2 Posts
