Trouble is the pre MY20 cars don't give you a %, if you get a 500 mile warning well how many litres have you got left, you know it's a 14L tank, ok your going to be safe putting in a litre at a time but where do you stop, there's no gauge to say 70,80,90% full like you posh guys haveThere are common issues with this "dosing" fault or "incorrect adblue quality" across diesel Ingeniums in other models too.
Often it's a crystalline build up on the injector which shoves the adblue into the exhaust.
It's also caused by a build up on the sensor in the tank if it is brimmed.
Always add 1 litre less than the car is saying to prevent that.
You can check the level on the ODB2 data socket.Trouble is the pre MY20 cars don't give you a %, if you get a 500 mile warning well how many litres have you got left, you know it's a 14L tank, ok your going to be safe putting in a litre at a time but where do you stop, there's no gauge to say 70,80,90% full like you posh guys have
Not true, my MY18 gives litres required in vehicle info menu available when engine not running.Trouble is the pre MY20 cars don't give you a %, if you get a 500 mile warning well how many litres have you got left, you know it's a 14L tank, ok your going to be safe putting in a litre at a time but where do you stop, there's no gauge to say 70,80,90% full like you posh guys have
Never trust any mechanic tbhNever trust a JLR dealer
My DEF tank is quite full at the moment so isn't showing how many litres can be added, just says refill is not required yet. Once the level gets lower it starts to show how many litres can be added. As previously mentioned it's wise to only put in 1 or 2 litres less than stated to avoid the over-fill error.
May be you should show him this. ^
(I suppose it's possible your MY16 is different to a MY18?)
Unfortunately all too often the jest below is too close to the truth. IMO
I wouldn't go that far.Never trust any mechanic tbh
Yes this is what they told me, the MY20 cars have a gauge, can't remember if its % or litres left in tank. If your told you only have 2 litres left then you know a 10L bottle will fit in with room to spare, if your told you have 200 miles left well how many litres do I need?I have a my2017. This one doesn’t show how many lters can be added. I heard from the landrover dealer that this indicator was added to newer models ..... when i was at the dealer because of problems because i overfilled it
I guess every model year is a different story.I have a my2017. This one doesn’t show how many lters can be added. I heard from the landrover dealer that this indicator was added to newer models ..... when i was at the dealer because of problems because i overfilled it
