1 - 17 of 17 Posts
Evoque 2012 panoramic roof
I can’t find anywhere to buy these anywhere in the uk. They are discontinued by Land Rover but I’m happy with a good quality alternative if anyone has any ideas.
Any advice or suggestions would be much appreciated. :)
P300E MY22 Autobiography
Hi Andy and welcome to the forum .. it might help us if you could let us know if you have a pano roof or solid roof ..
And what year your car is?
If it’s the series 1 I think they are the same rails but different cover plates.
I would watch he PowerfulUK you tube channel on the Evoque, they do a good video on the rails and I think sell them
Oops sorry, it’s a 2012 year
Hi Andy, follow the instructions below. It helps others and they don't have to ask you which year/model you have every time you have a question
Reactions: Gtiaps
Discussion Starter · #8 ·
Hi, I have a breakers yard near me that is good for Range Rover parts.
I have just phoned them and they don’t have any unfortunately. Thanks for your reply anyway. Cheers
2013 L538 2.2 RR Evoque Pure Tech td4
There appears to be loads to choose from on eBay.
ps, welcome to the EOC!
Discussion Starter · #10 ·
yes. Thank you very much.
Give these folk a try for used ones. they are JLR specialist breakers as well as Renault. Lots of late year stuff in as they are based across the road from Universal Salvage Auctions. I have used them as they are very close to me, not the cheapest but very professional.
Discussion Starter · #12 ·
Thank you very much I will get in touch with them.
2014 Evoque Dynamic 190 Auto
I purchased these last year, and they are excellent - They even come with pano roof trims in-fills, so basically they are all you need.
RANGE ROVER EVOQUE L538 2011+ BLACK ALUMINIUM ROOF RAILS RACK BARS OEM FIT | eBay
As for cross bars, depends what type you want. Powerful UK do an excellent set for the £150 region that are copies of the genuine JLR version, or Thule do various that are brilliant but obviously more pricey.
Discussion Starter · #14 ·
13 platePure SD 4 A / L538
Discussion Starter · #16 ·
2015 4x4 2,2 SD4 Prestige Business Aut
Hi @Noggin
Many questions but nice if you have time to answer. :)
The Ebay link says that "Fix point mounting - Mount using factory mounting point with no drilling required" but is this true? If I understand right you have to drill mounting points. It is not problem but just like to know.
are they same as these?
Those look more sturby than OE model too. Do they have lot of wind noise and do you have picture of yours?
What was the reason that you ended in these and not OE-models.
1 - 17 of 17 Posts
