1 - 12 of 12 Posts
I purchased a second-hand 2013 Evoque on 2019 and at my recent MOT I had an advisory to replace my corroded tank shield. I enquired at my LR main dealer about getting a replacement part and was informed that this item was not available from any UK dealership. There are no aftermarket suppliers of the shield. I presume that the tank shield will now fail at my next MOT, what am I supposed to do?
There must be many other Evoque owners with the same problem?
MY20.5 R-Dynamic HSE
There are plenty of other evoque owners with the same problem, the search facility at the top of the page is quite good I believe
Reactions: CoolBlueWhyte
Google is your friend
Wow, they've gone up in price - bought mine from there at £89 inc.vat. 18 months ago.
Ok thanks Doink but none of the posts i have seen really help. My problem is i cant get a replacement shield and i will most likely fail the next MOT.
Discussion Starter · #6 ·
Tried this supplier but they source from LR main dealer so cant help.
Don't know if this may help in your search, but the old part number is LR025815.
It is strange that these simple mild steel pressed guards are in short supply :unsure:
I wonder what is going on there?
Great find Nick.
From the text it sounds like they fit over the top, no mods required.
Nice fix if you have £218 burning a hole in your pocket :confused: 😀
Reactions: Nick12DMC
Saw those but they're an off road skid plate made of 4mm aluminum rather than a ton heat shield
Good point Doink, a hot exhaust melting your fuel tank should be avoided :unsure: 😀
1 - 12 of 12 Posts
