1 - 5 of 5 Posts
See Ebay listings 270900810188, 270900812224 and 270900814276
Discussion Starter #2
Meant to add - Happy to sell as a package for those brave enough to attempt an upgrade. Loom worth a punt if you forgot to spec fogs and want to attempt to fit a set and try to get them working. Whole lot would no doubt be a fortune from JLR.
Listing number have changed and are now 270904157887, 270904158407, 270904158720
Hi there,
Ihaveordered a pure with Tech pack without the front or rearcameras.
If i just connect the cameras will they work with the screen in the dash or does that also require anupgradeorsomething??
At the very least I would imagine it will need some kind of reprogramming by a dealer to enable the cameras. I'm sure it's much much more than simply connecting the cameras. The parts alone are going to be extremely expensive.
As front cameras are not an option on a pure, you may find that the wiring loam is in fact different and doesn't have the necessary plugs and sockets to even connect everything.
If you car is on order and not gone to build yet, you might consider changing your order and at least add the rear camera? (possibly the most important one).
1 - 5 of 5 Posts
