1 - 2 of 2 Posts
I had radiator leaking coolant on the alternator and it stop the vehicle
Replaced the radiator and used alternator and the vehicle starts and run normally but shows
1. Battery indication
2. Charging system fault on cluster
Two fault codes
Generator system performance
Lin
Can any body help me in this problem
which model and year Evoque do you have. It’s worth putting it into your signature so you can get more accurate answers.
Did you replace the alternator with the exact same type?
1 - 2 of 2 Posts
