1 - 11 of 11 Posts
Hi , I’m new here ! I’ve had a problem with my 2014 evoque for a couple of months . Sometimes when starting it throws the error message “ electrical management will shut down in 1 min “
Other times it throws the error “low battery please turn on in 3 min”
Now I took this to my dealer and they said it had a gateway module error so replaced it , this did not work and the messages soon returned , has anybody got any ideas on this please ?
New battery needed?
Try using a C-Tec (or similar) battery charger overnight and if the problem reoccurs in the morning when starting, then its probably not the battery.
If you do a lot of short trips the battery may just need charged as already suggested.
I do a lot of short trips but some longer . Could I just use a normal battery charger or does it have to be a special one ?
As far as I'm aware a normal charger will be OK but someone else on here might know better.
Ok , I’ve ordered a c tec charger will be here tomorrow , let’s hope that does the trick
Taken off charge this morning , fingers crossed when I drive it later ! Thank you to all who helped
Well upon taking it off charge this morning , it is good news ! All the interior lights are working and no more error messages so far ! Will keep an eye over the next week to see what happens !
1 - 11 of 11 Posts
