1 - 3 of 3 Posts
We have a 2016 Evoque and the door lock switch on the door does not work.The unlock works, but no lock. Anyone else have this issue? Everything works as it should with the fob.
Good chance its the actuator in that door. Common fault, Donna had issues and fixed hers with WD40 silicone spray but most people have to change the part.
Use the search function, this has been discussed many, many times.
I’m sure you’ll find the answer with a bit of reading other posts.
Good Luck!
Reactions: HmmmUK
1 - 3 of 3 Posts
