Bought a CTEK 5.0 as advised as getting low battery start engine on display due to not enough long runs due to lockdown
Charger got the battery to charged state but still getting low battery warning on display
The issue appears to be where to connect the Negative lead of charger to
Handbook says to large nut by washer bottle but CTEK lead won't reach !
Asked main dealer and they said on nut on clamp at negative battery terminal as the car has a BMS system
CTEK confirmed it has to be on chassis nut otherwise it’s charger will not give correct readings because the car has a BMS system
Bloody nightmare getting different advice!!
Can anyone advise if had similar experience as I am having and where they connected the negative lead of the charger to in order to get rid of the start engine low battery warning on display and the charger working properly
