1 - 8 of 8 Posts
Hi all, anyone have the answer to this issue. Thanks in advance.
On my manual ed4 2015 I release the clutch pedal and remove my foot from it. After a second or two I hear a clunk sound and the pedal has sprung up a further 2 inches above its normal alignment.
Everything seem to be working ok in terms gear selection etc.
As you can see it is starting to upset me :crying:
Discussion Starter #2
Ok as I have no responses I assume its just little old me and not a common problem.
Hi there - if you try a forum search for 'clutch pedal' there are some similar(ish) posts.
I only had a very quick look but it might be worth a look...
Afternoon, I’m a bit late to the party. Did you have any joy resolving this? I have the same issue, 2014 TD4.
I wonder if the Adjuster had got to the end of its range, or just worn out...
Not had this on mine (touches wood)
Holy thread resurection Batman!
Whats a clutch pedal? :unsure:
The adjuster should be at the top of the pedal under carpet and not easy to get to, there should be a stop too, so it does sounds like it's a problem there, but I've not looked at the Evoque installation
6630
1 - 8 of 8 Posts
