1 - 3 of 3 Posts
Got a check engine and this was the scan result. Tried clearing it but it comes back. Also it is displaying incorrect outside temperature. Has anyone got this? And is it simple as replacing the Sensor (located on the drivers side mirror) and then clearing the code? Any input would be great!!!
Very likely a sensor or wiring issue, so worth having a look to see if the wiring to the sensor (and mirror) is all connected up ok, before trying a sensor, of course JLR might make you buy a whole mirror assembly!
Thanks PhilSkill, I will take a look at the wiring but nothing has been messed with. Its funny because it 30 degrees here and its showing 60 F on the instrument cluster. Oh is a 13 Evoque Dynamic.
1 - 3 of 3 Posts
