1 - 9 of 9 Posts
Decided to do a service on the old evoque its early gen 2011 thought it would be straight forward but has become a puzzle the car cranks but won't start tried everything from priming to even pumping the air lock out from a pump and through the autel try starting with easy start cranks up but then revs a bit a and cuts back out any ideas what it is
Welcome to the EOC Qaz
Im sure you will have tried all this, but just in case….
Thanks for the welcome mate the guys did try to bleed it but was still being a nause im thinking can the egr cause it to not start
check any electrics you may of unplugged and if you are getting a good flow
from each injector when you crack them off while turning it over try a tow start
and the egr wont stop it starting.
unless its an auto i should of added.
It is almost certainly an air lock. I've had this on Ford TDCi engines. I had to put a large priming bulb in line and pump like crazy to get all the air out, then quickly remove it to stop the fuel draining back to the tank.
MY12 | 2.2 L Diesel | Dynamic Lux
I've seen people putting an air line into the fuel tank with a rag wrapped around it to push the air through the filter. I think you have to push quite a lot through to get all the air out.
1 - 9 of 9 Posts
