Hi!
I was wondering if anyone knew the both space dimensions in the evoque? I can find the length and height, but I have been searching for hours without finding the depth with the seats up. If anyone can provide me with this information, it would be very appreciated
Best Regards
From the brochure
Luggage Capacity - Rear seats upright
Coupe
Depth 796mm, Height 840mm, Width 1,090mm Loadspace volume 550 litres - Loadspace width between arches 1,000mm
5 Door
Depth 796mm, Height 870mm, Width 1,090mm Loadspace volume 575 litres - Loadspace width between arches 1,000mm
Keep in mind these are the maximum dimensions - as with any hatchback the sloping roof will encroach into the space. If you look the LR web-site, there are maximum box dimensions which perhaps gives a better indicator of whether you can fit something in.
Yeah, but I was worried that it was too small for a decent sized stroller. But I guess I will be fine, since the stroller is not that high
Land rover has said the boot is big enough for a set of golf clubs, even the larger clubs, so a stroller should be no probs.
Onebigjobby
