Hi everyone,
I've got a problem with a 2015 SD4 Pure Tech Automatic - two common issues but I have another question as well.
It's done 21000 miles since new, so not used much.
I have the common issue of the low battery "display will shut off" as soon as the ignition is off and the stop start has never worked - not essential. In terms of needing a new battery/having this battery calibrated by a specialist, which route is the one to go down?
Also, a few months ago the car went into 2WD with the reduced traction error message. It went away for a few weeks but is now back every time it goes over 20mph for the first time on a journey. What is the result of this, am I looking at a new Haldex pump (oil filter etc) because of the mileage and lack of use or is it more along the lines of a software update, with winter coming I want this sorted.
In terms of the 4WD system, as the car is a 2015, I have had differing opinions as to whether it is a Haldex system or an GKN driveline system, could someone more knowledgable direct me on this please?
Thanks in advance
Hi, welcome to the forum.
I would sort out the battery before getting the Haldex side of things looked at. A low battery is known to throw up this warning so I would see if the battery sorts things!
I also have a MY15 on it's original battery. Doing low miles and with the lockdown etc. I've also had battery warnings.
I've recently bought a CTEK charger:
CTEK MXS 5.0 Fully Automatic Battery Charger (Charges, Maintains and Reconditions Car and Motorcycle Batteries) 12V, 5 Amp - UK Plug: Amazon.co.uk: Car & Motorbike
For me, I'm no longer seeing battery warnings. I always turn off stop/start but knew this had given up, but after charging I tested this and found it was working again!
Like yours my battery is past its best so I'll be getting a new one if I see more issues - but having the 'smart charger' with another lockdown coming will hopefully help me keep going.
Searching the forum you'll see lots of threads on battery replacement - it's not a very clear picture!
When I replace mine I'll make sure the BMS (battery monitoring system) is reset.
Others haven't done this and don't appear to have been caught out. A LR tech did join a while back and said it must be done.
Over on the DS forum they mention driving for 40 minutes after replacing to avoid a BMS reset as the vehicle will calibrate.
They also talk about buying replacement BMS kit that sits on the battery terminal for around £30 which again avoids having a garage reset things.
Reactions: LancLand
That's great, thanks for that!
I was just wary about the horror stories of frying the infotainment etc. with using battery chargers on more modern cars.
Same, that's why I bought the CTEK! :)
On the earth side, best to use a nearby bolt rather than the battery terminal direct. CTEK mention this.
I guess it's so the BMS gets involved?
I have borrowed a CSI Airflow battery conditioner from a neighbour, is this ok to use or is it not suitable?
It should be ok as long as it says it's OK to use on AGM batteries if that's what your car has.
Reactions: LancLand
