21 - 40 of 41 Posts
Steve's clever bit on top of the basic dump and fill multiple times, was to fill through the Level setting access, rather than remove the gear selector between dumps to access the filling port.
Top Job if I didn't say already!
Reactions: Macdexx and Binty
That's why I love forums.
Gearbox fluid change has been on my list for the summer but had no idea how to do it without some research.
Apologies for resurrecting this thread. New to the forum but thought I would add an optional method to doing the fill after benefitting from @Steve D 's helpful advice and walk through here. Just did my first fluid swap earlier.
The fill port on a 2013 is easily accessible by removing the front left wheel. Once you do this, the fill port is right past the wheel housing. This will give you a relatively clear access to reach the fill port without having to dismantle the gear change unit. (which is good since I have to go back in there tomorrow to top off and re-level... I might have taken the leveling tube concept too literally as I allowed the fluid to leak until it leaked no more -- meaning I'm likely now on the low side)
One of the final steps to level out the new fluid before wrapping up the job is to bring the transmission fluid up to 50 - 60C. Can be accomplished using an IR thermometer or through the ECU -- however, there's no PID extension that I could find directly for the evoque.
I did find one on another forum for the LR2. The 2013 LR2 and Evoque are literally the same under the shell so tried it out. Seems to work (still need to verify with an actual temp measurement at some point that the ECU math is true):
PID: 22df0a
Long Name: Anything you want
Short Name: Same as above
Min Value: 0.0
Max Value: 100.0
Scale Factor" x1
Unit Type: deg C
Equation: A*256+B
OBD Header: 7e1
Is your MY2013 the 6 speed auto? I don't suppose you took a picture of where the fill plug is by any chance?
It is. Unfortunately, I thought I did but looks not to be the case.
That said, I can describe it. :)
Once you remove the left wheel, the transmission block is directly behind the wheel well. Off to the right side of the block, there's a bolt sitting at a 45 degree angle at the top. That's the fill plug -- you can confirm it by fitting a T50 bit into it. It it accepts it, then it's the fill plug (actually it's the only one at the position).
To fill it you'll need a hand pump or pressurized canister. The opening is 3/8" btw. I find it heldful to use a piece of 3/8" ro tubing to plug into the hole to bridge from the hand pump hosing. This keeps the fill hole sealed enough that shifting gears at each fluid swap cycle won't result in transmission fluid spraying from the engine running ( my experience matches Steve D's - took 6 drain and fills to reach an acceptable transmission fluid color) while keeping it conveniently enough to add fluid until you're satisfied.
Well CA_Evoque, that well and truly answered my question. Thank you very much, I feel like this is definitely something I can do myself now.
You can also pop the air box off, one 10mm bolt, a jubilee clip and couple of twisty clips in the wing and it lifts up and lays on the engine cover with wires attached. The fill plug is directly below as @CA_Evoque says.
I haven’t decided if best access is from above or to the side as I need to do mine this year. I might do both, side to remove the plug and airbox to allow a gravity fill. (I am too tight to buy a pump 😂)
Reactions: Macdexx
@Macdexx it's very doable. This was my first time doing the fluid swap. Started out feeling very daunted but once I figured out accessing the fill hole without having to remove the auto shift box, etc., it was very doable. ...and I might do this a bit more often. My original fluid came out black.
The trickier part is figuring out what level of "trickle" to allow for in terms of fluid auto leveling before reinserting the leveling plug. The answer is a mild sputtering stream. :)
@Binty I used one of these... at 8 USD, surely much more palatable converted to GBP. :D
The tube itself is too big to the fill hole but the 3/8" ro tubing i used to bridge is perfect . Snug fit into both the tubing of the pump and the fill hole itself.
Sounds like prostate issues to me 🥴😱
  • Haha
Reactions: Binty and CA_Evoque
Interesting post, I am looking into replacing transmission fluid in our 2012 Evoque with 6 speed Aisin Warner TF80SC gearbox.
After some investigation I believe there are 2 different setups of the fill plug:
  • 2011-2013 MY Evoque, with 6 speed Aisin Warner TF80SC gearbox, fill plug is right below the air filter box; If you remove the air filter box you will see the fill plug right below. easiest way to access.
  • 2013 onwards, 9 speed gearbox, fill plug is placed under 45 degrees, more on the side of the gearbox, accessible when removing front wheel.
Is this correct?
I have a 2012 Evoque. Not sure what make gearbox I have but it is the 6 speed.
I made a thread on how I did it here.
Reading these posts it looks like there are 2 different locations of the fill plug on an Evoque 6 speed automatic gearbox? On one the top (Below Gear Shift Module?) and one 45 degrees on the side, accessible taking the front wheel off. Are these the same 1 plug, I dont think so?
I wonder, the official workshop manual states that the fill plug sits at the top of the gearbox, for the awf21/6 6 speed auto. Would the fill plug on the side 45 degrees fit the later 9 speed auto transmission?
puzzled….who helps me out?
I may be wrong but I think the fill plug on the 9 speed is in a different location & is filled until oil trickles out of the fill hole.
I think there a few ways to fill the 6 speed. By removing the gear shift module, from the wheel arch, some have taken off the airbox and some have refilled through the drain plug but essentially we are all filling through the same hole if we have the 6 speed.
Thanks @Macdexx , that makes sense.
Seems I have found the fill plug under 45" on the side of transmission housing just behind the housing of the front left wheel (wheel angled to the right)....just above the drive shaft exit, see red circle. is that correct ?
I investigated the layout of the Aisin Warner AWF21 6 speed auto (TF 81-SC), and it seems indeed there are at least 2 fill plugs located on the top and the side of the transmission housing:
1. Fill plug on Top of transmission housing.
This fill plug is located just under the Gear Shift Module (GSM), item 4.
Also the air intake box needs to be removed, which sits above the GSM.
Item 6, Transmission control module (TCM) seems not to be in the way, sits just next to it.
I wonder if there is enough space between the fill plug and GSM to actually loosen the plug without removing the GSM.
The drawing above shows some space......
Below picture shows top view of GSM, and the fill plug is just below 1 of the fixation points/bolts of GSM.
With the GSM removed, the fill plug is visible, still slightly under the bracket that holds the GSM.
Note the TCM is still in place.
2. Fill plug at the side of the Transmission housing, 45 degress angle,
Below photos shows the location of the other fillplug as also indicated by @Macdexx .
Trust this clarifies.
Reactions: Gonzalo
21 - 40 of 41 Posts
