1 - 2 of 2 Posts
sorry for my english i am writing to you from italy i would like to ask you how often do you change the oil of the aisin 6-speed automatic gearbox and what does it consist of: replacement / washing / additives? thanks info
Hi, there are some good posts on here showing how to do it. Basically just fluid and the two sealing washers for the combined drain and level plug are needed.
Jaguar says sealed for life but I reckon 70 000 miles or maybe a a bit less is about right.
It is the same box as many other cars and there are some you tube videos. Try Volvo XC90 as an example.
Just make sure your get the correct fluid as I think the evoque gets the TF81 box not the earlier TF80
1 - 2 of 2 Posts
