21 - 35 of 35 Posts
Hi Mable,
The tailgate lights are great.
Where did you take the feed from and was it an easy job?
Thanks in advance for any info.
Tom
Hi Mable
They look great! 馃ぉ JLR should definitely fit as standard.
Don't forget to advise your insurance co. of the mods though 馃檮
Discussion Starter #23 (Edited)
I started from the factory left hand boot light, I used this type of wire tap.
Discussion Starter #24
Then threaded a pull wire up to the rubber boot, then again threaded another pull wire through the rubber boot, after this the last tricky part was up to the bottom of the boot lid from the rubber boot.
Discussion Starter #26
馃槀馃槀馃槀
I鈥檒l have a look if there鈥檚 any other sellers, I choose them as I thought if they fail would be easy to find and replace especially after hacking two holes in my shiny new cars boot lid 馃ぃ馃ぃ馃ぃ
Discussion Starter #27 (Edited)
The trim is held on with two 8mm bolts behind the warning triangle, use a plastic trim tool to pry off the panel
Discussion Starter #28 (Edited)
Last part was cutting holes for led鈥檚, I used a paper template to make sure they were a perfect fit, then drilled around marked aria with small drill finished off with a file
Then flip the template over and mark out the other side
Good mod and instructions 馃憤
Hi Mable,
Thanks for the instructions very informative.
Although in my case the word Destruction comes to mind.
Will have to have a go though.
Cheers
Tom
My OH won鈥檛 let me start cutting up our new car 馃檨馃槺
Here's my version of the boot lighting - a couple of LED strips mounted on the plastic trim at the sides, just under the parcel shelf.
4778
Looks really comfortable in there, can I make a booking if me & Mrs DK keep falling out 馃
MY20.25 P250 SE R Dynamic Silicon Silver, Black Pack, Pano, Driver Pack
What time is kickoff! 馃ぃ馃ぃ Seriously tho great Great job well executed well done 馃憤馃徎
21 - 35 of 35 Posts
