1 - 17 of 17 Posts
I have a ABS sensor fault showing on evogue. It has affected the power steering, ABS system and all the special driving programmes. I replaced the faulty sensor as the diagnoptics computer had said. Still have all the faults. Is this a broken cable in the wiring loom.
Hi Stephen, Which sensor did you replace, Abs is often caused by a broken Wheel Speed sensor, the Diagnostic computer can usually determine that well enough, if you reset the fault codes does it still say the same sensor is faulty?
On the dashboard it is displaying
Park brake fault
ABS fault
HDC not available system fault
Stability control system not available system fault
Emergency brake assist not available.
When plugged into the diagnosis computer it is saying rear abs sensor faulty. I have replaced the sensor, reset the fault and it is still the same.The speedo and the power steering is also not working.
Kennedy44 who has just joined too seems to have a very similar issue going on.
Hi Stephen, did you manage to sort this problem? I have the exact same issue on my 61 plate Evoque. My mechanic has so far replaced the sensor and the wheel bearing but still have all the faults! Nightmare!
Stephen hasn't been on here since August last year so you may not get a reply from him.
Well drove 20 miles or so yesterday and just as I was driving up a steep bank about to turn into the drive I lost the power steering, speedo and mileometer. On dashboard it is displaying
Park brake fault
ABS fault
Fortunately still under warranty with independent dealer. Emailed them last night and they rang me at 9 am this morning. They think it’s a rear speed sensor as they had one go on another one which showed the same faults so I’ve dropped it off for garage to have a look at it tomorrow. Will update when dealer rings me. Now driving a manual Vauxhall Corsa. It has two electric windows and a dab radio! Quite comforting really!
Hi Sadie hope it’s a quick ,painless fix for you.... my youngest has a corsa limited edition...I love having a wee go in it from time to time it’s nippy, fun to drive a manual now and then!
Thanks Donna. It certainly wasn’t fun driving to the dealers. Fortunately I’ve got a Tom Tom so I used that to watch my speed. Dealer says it looks worse than it is. Cant believe a sensor could do all that. Let’s hope so. Dashboard resembled Blackpool illuminations 😳. Quite impressed with the Corsa. Made me feel young again. Very nippy😜
Lol Sadie made me feel young again....
Charlotte Tilsbury magic moisturiser nearest I got to making me feel young again... going through loads wearing masks all day at moment lol
A lot of systems are now all interlinked and if one sensor goes down then other systems start getting upset and throwing fault codes, doesn't necessarily mean there's a fault with every one when you see the lights on the dash, a good diagnostic tool or a trip to the dealer will pinpoint which sensor has failed
Thanks Doink. Hubby was going to put his diagnostic tool on it but thought it might clear the fault before the dealer got to look at it.Dealer rang last night to say it was the nearside rear speed sensor. Part ordered and should be fitted today. They are going to drive it 15 miles or so then put the diagnostic tool back on it to make sure everything okay. Said they would ring me later today with an update. Collecting it hopefully tomorrow. I’ll post an update when I know for sure. It may be of assistance to someone in the future.
Good news (y)
Just going back to my other post, so you can see know how one failed wheel speed sensor upsets lots of other systems that use the info from the same sensor, park brake fault, ABS fault, Hill Descent Control not available system fault, Stability control system not available system fault, Emergency brake assist not available
I can now 🥴 I thought it had died 😰 Dealer did indeed ring me. All sorted and collecting this morning.
1 - 17 of 17 Posts
