1 - 12 of 12 Posts
2012 SD4 Dynamic Stage 1 500NM
Hi, I bought this around a year ago when it had 85k miles.
I got major service as soon as I bought it & haven't had any issues at all. Car before was a 1.2 corsa petrol haha & I was skeptical about the high milage as my corsa only had 25k but my dad said 85k for a diesel is nothing.
It's now on 100k miles, so I've done 15k in it since it's last oil change.
I'm a newbie when it comes to cars so now it's hit 100k miles how often do you recommend getting the oil changed? Every 7k? Do high mileage cars need more frequent oil changes than ones with less miles? What tends to go wrong with high mileage cars, or is it mainly just a stigma & all to do with how you look after it?
How long can this car last for if serviced regularly? Will it hit 200k if looked after?
Here she is.
Thanks!
8615
Yearly servicing or at 16k max as recommended should be fine.
Just checking the cambelt has been changed at it would be due at 7 years old?
Reactions: B4ines
I think when it went in for the service when i got it it had the Cambelt done, think I paid £110 for it? Like a belt with grooves init? Sorry I'm not mechanically minded
Hi - that sounds like the external belt that drives the alternator etc.
The cambelt change is internal and an expensive job. Failure will wreck the engine so worth trying to find if it's been done as the oil changes won't help here!
Reactions: B4ines
If it hasn't been done when I got it serviced is there anyway a mechanic would be able to see if it needs changing? Or is it impossible to tell a 1 year old one from a 7 year old one?
As the guy before me may of had it done a few months before I bought it so would be an unnecessary expense?
Thanks! :)
Thanks! :)
I think you'll need to rely on the service history.
Reactions: B4ines
Cambelt is essential at 7-9 years. had mine done last year with the service and it doubles the cost even at an independent, if you have any service history it should be mentioned or one of the last services will be nearer £1000 if it's been done.
The only other large costs coming will be changing the Haldex oil and filter and Diff oils that should be done soon on a 2012 (10 years).
Annual service or 16k will be fine on a 2012, although this year i'll be using my Halfords free MOT and not servicing due to the stupidly low mileage it;s done, since it was serviced.
Looks in good condition by the way!
Reactions: B4ines
Discussion Starter · #8 ·
Going in next week for engine oil change, cambelt. I will be providing the goods.
However I am wanting to get the diff oil done & the transmission oil changed. Online they say they are different oils but everytime I type in differential oil all I'm getting is triple / castrol, transmission oil coming up?
It looks like they are just adverts being displayed from the search!
I would be looking for the LR recommended spec.
Someone who's done it might post...
Reactions: B4ines
Discussion Starter · #11 ·
Is there anyway I can find out LR specific spec? Can't seem to find it.
Anyway a local garage is going to do
Engine oil change, filter & cambelt/water pump ( me providing ) & diff oil & transmission oil for £350. Total cost will be around £500.
I rang local land rover garage & I was told I couldn't supply my own parts, them all in £1250. Absolute madness.
If you look in the handbook all the oil specs are listed.
Ensure you have the low ash oil to protect the DPF. I think it is Ford 934B spec from memory but it is in the handbook. Millers oils do one at a reasonable price.
Reactions: B4ines
1 - 12 of 12 Posts
